I have just read a thread here on this very subject but then lost it.
Anyway I wanted to ask more questions,
The component I wish to solder to a prototype board is a 36 contact IC 5mm x 5mm.
Linear LT3651 IUHE-4.2#PBF.
The contacts are not visible from the top which surely presents a special problem.
I just can't see myself accurately holding this in position, then soldering How exactly,
If I allow solder to run under the IC no doubt I'll get contacts soldered ................ each to the rest!!
Can't see how you can clean that up with wicking.
Am I being negative, this is far smaller than other tasks I have tried & steadiness of hand is not one of my attributes.
Which leads me to ask the obvious question:
Why don't IC manufacturers make a larger base unit with flying leads into which the SMT IC can be safely & securely snapped into position. Or, offer a "mount to small GP board" service?
Look forward to a spot of guidance.
Rgds all
Peter O
Rgds all
Peter O
