I have 16 50W halogen lamps in my kitchen ceiling. The lamps are 12 volts with 5.3 bases. Whoever installed them buried the transforme in the ceiling and wired it back to a switch on the wall. I have no idea where the transformer is or where the wiring is running.
When I replace the lamps with led lamps they start to flicker. This is not surprising as I guess the 12 volt output from the transformer is not very regulated. Obviously this is fine for the halogens but not the leds. The answer of course is to replace the transformer with an led driver transformer that will give 12 volts regulated output. However I cannot do this as I have no idea where the transformer or the wiring is and short of ripping down the whole ceiling have no idea how to find it.
I guess all the fittings are wired in parallel. Does anyone have any ideas how I might sort this problem by adding something in parallel with the 12 volt supply in the ceiling void. The only thing that I can think of is to wire a 10,000 microfarad capacitor across the 12 volt supply and see if this provides enough smoothing. I am not sure I am that happy with a large capacity capacitor in the ceiling void, or whether this is even large enough to provide sufficient smoothing. Has anyone got an better ideas???
Cheers
Tony
Cheers
Tony
