I am not new to electronics but I don't know Jack Schmidt about SMPS's. I am looking to build a step down dc to dc converter from 250 volt dc to 5 to 12 volts at 100 amps. For over current I am thinking of using cycle by cycle protection using this hall effect sensor http://www.lem.com/docs/products/lf%20306-s%20e.pdf and a nand gate. Pwm is sent through the nand gate as normal until a particular current is reached and a positive voltage is sent to the other lead of the nand gate shutting off current for sometime. My questions about this current sensor is on the data sheet what is meant by with 12 volts and with 15 volts on the first page? Is this the required supply voltage to the sensor or can a lower voltage like 5 volts be used? If voltage out of the sensor is proportional to the amount of current in the sensor how do I make sure that the nand gate shuts off at the desired voltage say if I am using 5 volts to supply the sensor but I want the nand to shut off at 2.5 volts or 150 amps of current? And can a toroid withstand 100 amps? How big would it and the wire and core have to be?
