toyo22r
Hello,
I am somewhat new at smps. I am designing a simple circuit to amplify
square wave 400hz signal to 340Vpp signal. Am I correct to assume that
half bridge drive circuit is for single rail only (ie positive swing) an
that what i should use is a full bridge driving 4 MOSFETs?
Also I breadboarded a half-bridge circuit driving 2 MOSFETs. The rai
voltage is rectified line from a variac so that i can ramp it up slowly.
The output signal looks good until I reach about 80V. The the signa
appears to saturate and its amplitude stays at about 60V and will no
increase even with increasing rail voltage.
Thanks in advance.
Paul
Thanks in advance.
Paul
