Hi all,
Im once again, trying to make an induction heater with a half-bridge driver IC, but im running into problems, I would like if someone could take a look at my diagram and see if im doing something obviously wrong..![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If I turn off the 31v rail the IC gate signals look fine, but if I turn it on, the IC gets very hot, the inverter appears to draw alot of current and I must turn it off immediately or im risking my transformer..
The PWM signal is comming from my signal generator, the first part of my circuit is my attempt at making a dead time logic circuit, i've measured it with my scope and it appears to work just fine.
Gate signals from the driver also appear to be OK, are out of phase as they should be and are not cross conducting.
The +15v supply is comming from my bench PSU, the +5v is comming from a LM317 regulator that's fed by the 15v supply, this works fine too, all circuit common are connected..
My resonant circuit consists of a work coil made of 3mm cobber tubing that I made myself, I chose a 100KHz resonant frequency as it is the highest my LCR meter will measure, I used the resonant frequency formula to solve for a value of C, giving me 1,613uF. 1,57uF was the closest I could get to that and that gives me a resonant frequency of 98,9 KHz..
Not sure how to solve for C10, it's just a blocking cap, big enough to not influence the tank circuit is the goal I guess..
Also not sure how to calculate inverter current draw, when driven at resonance it should be very small if im reading things right, not sure, it can wait for now I guess.
The fets are IRLB3036's : https://www.infineon.com/dgdl/irlb3036pbf.pdf?fileId=5546d462533600a40153566033ea2589
The IC is IR2110: https://www.infineon.com/dgdl/ir2110.pdf?fileId=5546d462533600a4015355c80333167e
Here is my circuit diagram, the 31v rail isnt on here.
The 31v supply is comming from a transformer with two 22v secondaries in parallel, running into a bridge rectifier, 1000uF smoothing capacitor, that's it.
I can show the calculations that i've done if it's of any help.
Any help is appreciated guys..![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![Sch.png](/forums/proxy.php?image=https%3A%2F%2Fwww.imageupload.co.uk%2Fimages%2F2017%2F07%2F23%2FSch.png&hash=0587c9b03d9e39cc4576817f50583b33)
![IMG_0303.jpg](/forums/proxy.php?image=https%3A%2F%2Fwww.imageupload.co.uk%2Fimages%2F2017%2F07%2F23%2FIMG_0303.jpg&hash=35d17fc118bb4f23dd16298d48df53b7)
