HA13150A Audio Amplifier
They are both inputs. Page 8 has an example of how to use the mute input.
I imagine you could do something similar for the standby input.
Do you want to use either feature?
i don't need the features, what exactly is the standby supposed to do?
If you don't need the features, tie both inputs to +5V.
Standby puts the amplifier module into a low power mode (effectively turns it off).
What else can I do to improve the quality of the sound?
Its datasheet shows that it produces low distortion if you keep the output per channel less than about 12W per channel into 4 ohm speakers. Simply turn down the volume until you do not hear any distortion.
yeah i just hope that 12W is loud enough for me hehe
24W with low distortion sounds only a little louder than 12W at low distortion. 120W with low distortion sounds twice as loud as 12W with low distortion.
Because our hearing's sensitivity to loudness is logarithmic.
