Hello
Im interfacing IMU gy80 module with TivaC board.
Accelerometer is working fine.
Gyroscope & Compass Readings not changing continuously but when the device is power OFF and again ON that time readings before power OFF and after power ON are different.
BUT untill the device is powered off the readings will remain constant.
Hers my part of code..
I'm initializing the L3G4200D gyrometer registers with following mentioned values
writeI2C0(Gyro_ADDR,CTRL_REG1,0xCF);
writeI2C0(Gyro_ADDR,CTRL_REG2,0x00);
writeI2C0(Gyro_ADDR,CTRL_REG3,0x08);
writeI2C0(Gyro_ADDR,CTRL_REG4,0x30);
writeI2C0(Gyro_ADDR,CTRL_REG5,0x00);
signed int getRotation_Y(){
signed int short raw = (signed int short) getRotation_rawY();
signed int Rotation = (signed int)raw;
return Rotation;
uint16_t getRotation_rawY(){
uint8_t rotData1, rotData2;
rotData1=readI2C0(Gyro_ADDR,OUT_Y_L);
rotData2=readI2C0(Gyro_ADDR,OUT_Y_H);
uint16_t rawY = (rotData2<<8)|rotData1;
return (rawY);
UART_OutUDec((unsigned int) rotationX)
if(n >= 10){
UART_OutUDec(n/10);
n = n%10;
UART_OutChar(n+'0'); /* n is between 0 and 9 */
return Rotation;
return (rawY);
if(n >= 10){
UART_OutUDec(n/10);
n = n%10;
