hi guys, been building a few fuzz pedals lately and found a problem with a certain brand of power supply.
when the fuzz is on its own, or with a isolated multi power supply every things fine and dandy.
but, when its plugged into a multi power source where each output shares the same common ground / not isolated, its shorts the power supply out. im at a loss as to why this happens, as the input/output jacks are straight to ground, and the led is grounded through the chassis. only thing i can think is that ive soldered the led resistor to the cathode and that resistor goes to chassis round... could there be some voltage crossing due to a lower value resistor that means ground isnt 0v? a small voltage on ground / short here was the only thought the makers of the power supply had!
cheers, and thanks in advance for any help! thomas
