So I've been trying to do my own research on this.But just confusing myself.
I figured this would be simple enough to do so maybe someone on here can point me in right direction and help me.
Basically I'm helping out a school with a project.
Main reason I'm doing it is because I'm a a laser person and know how to build them
So this is what I have.
I will have a light shining on a photocell, when the light is broken I need it to trip a relay for probably just 30 seconds. There will be a 24VAC line coming into the project box which will be split. The circuit board will run from a 12VDC line that has been converted from the 24VAC.
a friend mentioned to me about using a 555 timer. Says there reliable, easy to use and cheap.
So can someone kind of help me out with this on what I need to do to build this circuit?
Thanks in advance.
Thanks in advance.
