Grundig YB400 service manual needed
msg
Greetings:
I have built a software controlled receiver based on
the RF section from a Grundig YB400 (YB 400, Yacht Boy
400) radio; I have the schematics from the Grundig
service manual (kindly posted to a web forum) but
I need to locate the remainder of the service manual
for component call-outs and alignment data among
other things. I have generated some call-out graphics
from tedious tracing under a magnifier but many
components are hidden under shields which I won't
remove until necessary and tracing the remainder of
the rig would take quite a stretch of time.
Doe anyone have this book in electronic or hardcopy
form?
Much thanks in advance,
Michael
Arfa Daily
msg said:
Greetings:
form?
Michael
Software Controlled Radio or Software *Defined* Radio ? If the latter, I
would have thought that a Yacht Boy would not have had the front-end
performance to sufficiently showcase an SDR module. Just interested. Sorry,
don't have the service info for that model.
Arfa
Michael Black
It's an old style radio.
ANd the guy hasn't designed anything, he's stealing the design, and
hasn't even gotten that far, or else he'd not be looking for the schematic.
When I got an older Grundig shortwave receiver last fall at a community
sale, it wasn't long before I had the cover off, and at least had a general
layout of the circuit, just by looking at it. If someone is going to
steal a design, at least they should do thw work.
Michael
msg
<snip>
Thanks for your reply; no it is not SDR. The RF section from the
radio was a convenient starting point for a personal project.
Regards,
Michael
msg
Michael said:
"Arfa Daily" ([email protected]) writes:
<snip>
Please refrain from unwarranted vitriol; in my post I stated that I had
the schematics, I just hoped to find the rest of the book. This is a
personal project and I should have written 'used the RF section from
a YB 400' rather than 'based on the RF section from a YB 400'. Aren't
there any homebrewers here?
Regards,
Michael
msg
msg said:
Greetings:
Does anyone have this book in electronic or hardcopy
form?
I must mention that I tried to purchase a manual
from 'Eton', the current owner of the Grundig radio
line and I was told that they don't have this manual,
that it was unavailable to them. Ergo, my usenet
request. The service manual was published in Germany
and was not restricted.
Regards,
Michael
Michael A. Terrell
msg said:
Aren't there any homebrewers here?
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
msg
Indeed; if you check the archives you'll find my post
to that NG with this request some weeks ago. It seems
to me more likely that folks involved in depot repair
and service will potentially have the manual and are
more likely to read this NG...
Regards,
Michael
Michael A. Terrell
Have you contacted the factory authorized service center(s)?
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Arfa Daily
msg said:
<snip>
Regards,
Michael
Yes, I am both licensed, and an old-school home brewer, which is why I was
interested in exactly what you were talking about, and what you were trying
to do with it. This month's RadCom has an article which actually deals with
the principle of what it would seem that you are trying to do, using an old
FT290 as a VHF front end for an SDR module - that's assuming that we are
talking SDR here, a point which you haven't cleared up yet.
Arfa
Arfa Daily
msg said:
<snip>
Regards,
Michael
OK. That's that cleared up then. So what exactly are you controlling, and
with what software ?
Arfa
msg
Thanks for asking.
I designed a digital section to control the pll 1st LO, filter selection,
BFO, and misc. power and control lines with provision for additional signals
as the design progresses. I modified the RF section to accommodate my digital
design, removed superfluous components no longer used and added modules at
appropriate places where real estate permitted, changed the antenna input
circuits and provided a 50 ohm bnc input. The RF section and digital
section are separately encased in faraday cage shields, all dc lines are
bypassed and filtered, serial i/o is ferrite choked and ground straps
are liberally used. I have work to do yet to quench processor clock
harmonics and mcu conducted RFI on a small number of i/o lines between
the modules (I've reduced this RFI by about 10db since I started...). I
may need to do some software-based autonotching to move the birdies out
of the passband dynamically.
I download operating code over an rs232 port which also serves as the
control interface and I'm writing a comprehensive VT100-graphics based
control program for a systems-agnostic way to operate the receiver.
I will be posting a link to the website documenting this project soon
(in rec.radio.amateur.homebrew) and will provide online access to the
receiver with realtime RTP audio streaming.
Regards,
Michael
DaveM
Regards,
Michael
You might try http://home.arcor.de/walter.groer/schema.htm. They seem to have a
pretty good stock of manuals and schematics for European made radios, including
Grundig. The Grundig page lists the YB-400, but don't know if it's the complete
manual or just the schematic. Six pages, if that helps.
Dave M
MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
address)
Life is like a roll of toilet paper; the closer to the end, the faster it goes.
msg
Thanks for the lead; I know that the service manual has at least
20 pages and the schematics as foldouts occupy 6 A4 pages so he
must have only schematics. Also, he lists the year of introduction
of the YB400 as '81 which is a bit odd since many ICs it uses weren't
produced until the late '80s :) However, I will email him and inquire
further.
Regards,
Michael
Arfa Daily
msg said:
Thanks for asking.
signals
digital
Regards,
Michael
Interesting project. I'd like to see the website when it's available.
Arfa
msg
Hi, I sent you an email with the URL to my preliminary site for
accessing the receiver. If you did not get it, please contact me at
msg _at_ cybertheque _dot_ org.
Thanks,
Michael
