Grundig XS70/S horizontal hold problem
Jerry G.
This is generaly from failing parts in the pin cushening amp section.
It is also possible that other parts are wearing out from age in the
power supply and the scan section.
This is not something you can fix yourself, unless you are skilled at
troubleshooting TV sets, and are equiped to do the service work.
I would suggest you give the set out for a proper estimate, so you can
make an intelligent decision to service the set or not. Using the set
like this may cause more damage.
Jerry G.
Jens Klostergaard Lyngsoe
Hello,
My Grundig XS70/S (CUC6360) suddenly shows a very narrow picture with
the left and right sides as arcs making the picture look like this: )(
with large black areas in each side.
I believe this problem in danish is refered to as "vandret billedhold",
directly translated it would be called something like "horizontal
picture hold".
How can I fix this?
Also, the Text TV and internal menu system of the tv is only sharp the
first 2 minutes after power on. It then becomes more and more shaky and
unclear, leaving it completely unreadable.
My only guess could be of dried out capacitors or creaping currents due
to dirt..
Please advise!
Kind Regards
Jens
________________________________________________________________________
Home: +45 8665 8796 mailto:[email protected]
Work: +45 8750 4594 mailto:[email protected]
"Follow your heart and forget your brain"
(Lester Young)
Thanks John!
It was set to -8, should be +1, I never noticed till now,
/Jens
Fix your Date and Time
Home: +45 8665 8796
Work: +45 8750 4594
Pligttroskab - bærer lønnen i sig selv, men den er beskeden
Hæderligheden - smuk, men mager
Retfærdigheden - stolt, men enøjet
Kærligheden - sød, men kostbar
Venskab & Kammeratskab - godt at tænke på, når man bliver gammel
Men det eneste der BETALER sig - det er forbrydelser!
(Jensen, kriminalassistent af 1. grad)
Thanks Jerry,
Though I'm electronically educated, I'm definitely not a tv-repair man,
so I think I'll get a grip of myself, and try not to get in even more
trouble by trying to fix the problem myself.
Thanks for your fast advice
/Jens
Home: +45 8665 8796
Work: +45 8750 4594
