mm said:
Do I need to ground an antenna in my attic? (The web page talks about
outdoors and putting the ground right where the cable comes into the
house, which implies I don't need one for the attic, afaict.
I installed an electric circuit straight from the breaker box to the
attic, and I know I connected the ground wire. Can I use the electric
ground?
Or do I have to run a new wire?
What are you using the antenna for? There is a big difference between a ground
for electrical safety and an RF ground for signals. If it is just for reception
e.g. a TV antenna, then there is no need for an RF ground.
For electrical saftey, the antenna should be connected to a lightening arrestor
and that connected to ground. I don't know US electrical codes, but I think
that it has to be a separate yellow green wire.
Since you are inside a house, it is almost impossible for lightning to
strike your antenna, but a nearby lightning strike can still do a
lot of damage.
For an antenna that is directly coax fed, i.e. one side of the antenna
is connected directly to the coax, a "ground block" will do.
Here is an example:
http://www.radioshack.com/product/index.jsp?productId=2150597
Most TV antennas consist of a metal boom, with elements that are insulated from
it. In that case, you should put the grounding block directly on the boom,
and connect a short coax from the feed point to it.
Run a ground wire from it common ground rod where the electricity enters your
house.
Note that you do not have to run the ground wire from the antenna, you can
ground the boom to the coax using a grounding block, and at the other end
run a ground block and grounding wire to the main ground. This works
electrically, it may not be legal in the US.
BTW, it is never a good idea to use the ground wire for an outlet for an
antenna, someome may disconnect the outlet without realizing they are
disconnecting the antenna too.
Geoff.
