Ground loop
Hy
I have put out some Bluetooth speakers with active amplifier. I get noise from ground loop.
How can i remove it.
The power goes from ac 220v to 12v 1a converter to amp, and from that same converter to step down converter 5v,that is used to power Bluetooth doongle.
I have read that isolated power module from 2 converter 5v to doongle would solve my problems, is that true, and is therr some other solution.
Is this definite?
The noise can also come from a noisy power supply as you are using a switch mode regulator. Try to power the blue-tooth dongle and the amplifier from a separate, preferably isolated, power supply, e.g. a USB power bank and a good benchtop power supply.
  • If the source of noise is from a ground loop, it should vanish when using this setup.
  • If the noise persists, it comes from teh step-down regulator or the 220 V to 12 V converter. You can try to minimize the noise by adding addditional filter capacitors to teh power supplies.
ok .ty i tried to put cap after 12v regulator and it did give some less noise.do i need to put one before the regulator,
on 220v current
on 220v current
Definitely not. The noise is produced within the switching regulator. This is a normal effect of a switching regulator's operation and needs to be filtered well.
A better filter uses an LC combination. You can get them at low cost for filtering car audio power supplies.Ask your favorite search engine, use search terms like "car audio power filter".
