Ground loop problems
Dick
I have only rudimentary electrical - electronic education and
experience.
I appear to have a ground loop problem with my home entertainment -
computer system. Here is the nature of the problem:
I wanted to route all the audio signals (TV -Satellite, VCR, and
computer) through the AUX input on my stereo amp.
Whenever both the TV and computer are connected to this AUX input
(through use of a switching box) there is 60 hz. hum.
All appliances above receive power via a common Panamax power
stip/surge protection device.
Previously, I had a problem with hum when I connected an FM signal
(which is split off the VHS signal) to the stereo tuner ALONG WITH the
computer's audio signal. I solved this by installing a small inline
slider switch on the FM line, so I could break that connection when
not listening to the radio.
It would appear that the conflict is between the VHS signal and the
computer.
I have not yet confirmed this by disconnecting the VHS coax from the
splitter box - only disconnecting the coax from the back of the TV.
I do NOT suspect a conflict between the satellite signal and the
computer, because as soon as I throw that switch on the FM line, there
is no hum.
So.....what could the solution be?
Are rooftop antennas supposed to be grounded?
Dick
Mark
If, in fact, they all have a common power source, than your
problem is Not a ground loop.
I've read that a number of times, and still can't make sense
of it. You're getting radio broadcasts from a VCR? Please
explain your connections.
computer.
By "coax" are you talking about a CATV or antenna feed, or
an audio or video cable?
is no hum.
Still confused by what this FM line is.
Generally, no.
Mark
The truth as I perceive it to be.
Your perception may be different.
Triple Z is spam control.
CJT
That's not necessarily true. It just makes a ground loop less likely.
CJT
I should have said it makes a ground loop _problem_ less likely. The
loop will probably still be there, consisting of two (or more) power
cords and the A/V connection(s) between the equipment.
