Windsun said:
1. Batteries cost money. Batteries have to be replaced. Over 20 years life
of the system the batteries would probably end up costing you more than the
solar panels.
You are overstating the case by A LOT.
I have two dozen T-105 batteries. They cost around $60 apiece,
including any recycling fee -- that's an investment of under $1,500.
I've had 'em for 4 years. I run an equalization cycle every 6 months.
Takes me about an hour of my time, now that I've found the auto-fill
bottle thingie (most automotive parts stores have 'em). I'm not seeing
any signs of degradation. I figure they'll last me 10 years, so I'll
have to put in another $1,500, maybe $2,000 if recycling costs go up,
before the whole system needs to be replaced.
I have 32 Kyocera panels. Those puppies cost around $500 apiece.
That's $16,000 worth.
I probably paid an extra $3,500 (including the batteries, charge
controllers, and an inverter/charger/grid-tie-capable system) to have
that battery bank, perhaps $5,500 over the life cycle of this system.
For my goals, that was a relatively small cost in order to be able to
run independent of the grid, if I have to or want to.
2. Direct grid tie inverters are more efficient than the grid tie with
battery inverters in feeding max power from the panels to the grid. And you
also have the additional losses of going from panels to charge controller to
batteries then to grid AC.
The charge controllers generally don't have anything to do in my system.
While the grid is up, they're out of the picture entirely. Excess
power is dumped onto the grid.
They only have something to do if the grid is down while the sun is up.
From what we have seen in installed systems the
total loss with batteries is 15 to 25% more than a straight grid tie.
3. The average power outage in the US for all causes averages less than 6
hours per year.
Well, I'd be very surprised if those numbers applied to my system. I've
got a 3kw system that supplies me with over 14 kwH per day, averaged
over the course of a year. The panels are not on trackers, and they're
not even at optimum elevation or azimuth.
