Greetings to all members electonicspoint
Status
Not open for further replies.
Greetings from me to all members , I am new here . I expect you to give me guidance in this area Reddit gods rewand you for sharing all of this knowledge.We are admonished me wrong , do not want arrogant ya.
Welcome.
I for one, am not looking for rewards; Reddit gods, mortals, or other.
I am happy to share what little knowledge I have.
I apologize for whomever "we" is, and his admonitions.
I have learned that having expectations is seldom conducive to peace of mind.
Welcome.
Thanks Bro ,
Bro , I want to ask , can?. I want to learn to repair laptop motherboard.Where should I start , can man guidance to me
Your pursuit is quite advanced, even for someone with years of experience.
You could start by examining the pcb for hairline fractures or cold solder joints. Some times you can get lucky with something like that.
What are the symptoms it exhibits? What is your level of experience? What test equipment do you have? Dealing with the tiny scale, smt components, renders many repairs on motherboards impractical if not impossible.
hevans1944
Hop - AC8NS
The biggest problem I ran into was attempting to remove a faulty power jack from a multi-layer motherboard using just a soldering iron. Can't be done without ruining the outside layer circuit traces. You need some way to heat both sides of the board and the vias to get through-hole parts removed without damaging the board. I might have been able to do it with a hot-air re-work soldering station, which is mandatory for removing smt components anyway, but I didn't have one and had to return the motherboard to its owner without repairing it. You have to be aware of your limitations in tools, skills, and experience. Re-work de-soldering stations start at around $200 and can go up to several thousand US dollars, depending on capabilities. You might be able to adapt a hot-air gun to the job, but you need some way to slow the air-flow or the smt parts will get blown away. I am looking into that for home projects, but so far no success. My hot-air gun is currently too unwieldy for the purpose. Maybe if I can find some sort of thermally insulated, small diameter hose to attach to the end it might work... maybe a braided-steel covered water hose wrapped in insulating tape would work. Have to be careful not to melt the rubber lining of the hose, so maybe Teflon tubing would be a better choice of material to use.
Status
