Green picture from scart
Hi!
I have a problem that I´ve never seen before!
I have a got an VCR/DVD burner thats show a green picture on some screen
It´s an Grundig GDR6460 (I think it´s performed by DAEWOO?)
On the owners screen and one of my LCD screen the picture is green. Even in setup mode
When I connect the unit to another LCD screen it is fully correct (LG screen). I have also connected it to an older TV and it is working fine. i have also trid to changed the scart cable!
The output on the unit is set to RGB
Have anyone seen this problembefore?
If the problem is only with a particular display, the problem is there. Check the SCART connections (though unlikely), pins 7 and 15, the Blue and Red signals. The problem could be the Red and Blue signal amplifiers.
Yes! I also get this thougt at the first time.
I will check and compare the red and blue signal on scart again
The most strange is that it appears on two separate screen. If I connect another unit (VCR,DVD or similar) there is no problem at all. The screen are fully correct with corect colour (on all screen)
The SCART connection handles both RGB and Composite video;
Pins:
7 Blue, 11 Green, 15 Red
19 Composite OUT (video source), 20 Composite IN (Monitor).
16 RGB or Composite select (decided by the video source)
What is (are) your Monitor(s) selecting? RGB or Composite?
Let's say that for the VCR or DVD composite is being selected by the monitor. Its fine.
But for the Grundig, its choosing RGB and there is a problem.
or the other way round.
Check the pin 16 voltage (Binary) in your various connections and that will give a much clearer idea to the problem.
Additionally, do all the monitors have a RGB option? Maybe the working ones choose Composite irrespective of the Pin 16 status.
Thanks for your help!
When I disconnect pin 16 it's working absolute correct!
Next thing to discover is to see if the problem depend on VCR or TV.
Time to work on
