Hi All,
I'm in the process of designing a grease gun which builds up pressure to 500psi using a 12V DC motor and a cam to move a piston which builds up the pressure. The system will be battery powered.
I'm having trouble coming up with a circuit which will turn the motor off once the current draw reaches a certain level (corresponding to the load on the motor once 500psi is reached). I then would like the motor to turn back on after say 5 seconds, and either
A) start running again if current draw is less than that required to build up 500 psi
or
B) turn straight off because the system is still at 500psi and therefore current draw is at the limit.
Are there any suggestions which you guys can give me or point me in the right direction?
Many thanks!
or
Many thanks!
