Hello. I have small GPS Vehicle tracker. It is connected to small 12V Lead Acid battery (the one used in UPS devices). GPS Tracker runs on the small battery for about 3 days. I was wondering if it is wise to connect the small battery also with 12V motorcyle battery (parallel connection). The Idea is that GPS Tracker + small battery are both hidden inside a motorcycle but connected to motocycle battery. When rideing, both small battery and motorcycle battery takes charge and when parked, the GPS device lasts more than 3 days. And when motorcycle battery is disconnected, the GPS Tracker still runs on the small battery for 3 days.
The GPS Tracker is designed to be connected directly to vehicle battery but when a theif disconnects the vehicle battery the GPS is turned off. Thats why I want to use small battery between the GPS and motorcycle battery.
