Sir fmevanspe . . . . .
OH TAY ! on your forthcoming comments and the similarities / disimilarities of the supplied GOULD 400 series power supply . . .versus your 465 version.
I would at least suspect some high degree of carryover of their shared initial design aspects.
Now with your mentioning of electrolytic capacitors and the potential manufacturing window timeframe of your unit
Check out the supplied reference below with due concentration of particular interest to the series of 4 small silver colored mini aluminum-i-ninny-yum-yum can electroytics and their surface mount aspects with their black square molded plastic disc / spacers, that they are being mounted upon.
Now, with your FOUND marginal E-caps . . .any chance that they are of the type that you are encountering as being used in your unit ? ? ?
IF so . . . . . . . boy . . . . do I have some stories for you.
ALSO . . . since that power supply primary input is being a mere 24v . . . instead of a full 160-320 VDC that typical supplies use, any chance that the switch mode portion is operating, with you getting any DC voltages out of the 4 supplies on the far right side of the supply ?
REFERENCING . . . . ( It is being from a completely
DIFFERENT other products circuit board
But it uses BOTH sides of the board with its foil traces, and sometimes a fine trace is routed under /between one of those E-cap types pairs of terminals.
https://i.stack.imgur.com/2rMdM.jpg
ZUJ'ing ***. . . . . .
. . . . . . . .for your reply . . . . .
https://en.wikipedia.org/wiki/Z_code
https://ham.stackexchange.com/questions/345/why-do-hams-often-conclude-messages-with-73
73's de Edd . . . . .
My wife queried me as to whether I thought that she was fat . . . . I then thought and tactfully replied " NO ! you're just being easier to see."
and then . . . . . W H I Z Z Z Z Z Z Z . . . . . . came the flying shoe.
