I want to buy some rosin flux paste, and I was wondering what are some brands that you guys prefer (or maybe they're all just the same)?
thanks
thanks
Why do you want a paste. Are you planning to use it as a tip cleaner?
I use 100g. yellow plastic pot of FRY POWERFLOW FLUX (IT SAYS IT'S THE IDEAL FOR LEAD-FREE SOLDER.I want to buy some rosin flux paste, and I was wondering what are some brands that you guys prefer (or maybe they're all just the same)?
thanks
Now you're talking about Liquid Flux? As used to reflow MoBo's? Michael Studio1 UK 21:10BSTI am retired now so haven't done any SMD for a while but I used to dab a pad (just one) with a drop of flux, tin the soldering iron and dab it in turn on the same pad. Now place the component on the pads and touch the tinned pad with you iron. For the other connection, a dab of flux then touch with the tinned iron. Result : perfect joints.
+1LA-CO
As for solder... I hate using lead free solder. Joints tend to fail alot !+1
also a bonus tip........ I use the tiny bit of paste to "tin" wires by dipping in the paste and heating one of many large globs of "real" solder found on old circuit boards and then rolling the wire. If doing many wires for rough projects it helps save the precious new solder ($$$)
