What bench top power supply
Hi again Zerotolerance.
I would say a bit more voltage, not a lot more but a bit, and current up to 10 amps, a variac is a handy thing to have, it gives you from the mains supply a variable AC voltage.
To go out and buy a good quality supply is not cheap, for a lot of house hold electricals you can start with a modest PSU a lot of fix and repair of consumer electricals dont always require power to be applied from a supply, working on house electricals means at some point you might have to work on live mains powered circuits, yes its a dangerous procedure, but if good safe practices are followed, along with the correct tools its safe.
I would learn the basics first, even before purchasing a power supply, the theory in books and on the internet will help you understand how circuits and components in them work, and behave under what is often very different circuits from one electrical product to the other.
If you dont get a grip on the basic fundamentals you will not understand if when and why faults develop.
To cut a long story short, i became ill, and what hobby's i had went out the window, scuba diving, shooting, firearms, fishing.
Ive always had a fascination how things work, after becoming unwell a lot of the time i had to find a hobby that suited my changed life style, not my choice, yet i wanted a hobby, and i did it from scratch, it takes time, even now i am continuously learning, its a hobby / profession, you never stop learning as the electronics technology is constantly evolving.
So the best advice i can give anyone new to electronics is start from the bottom with the basics, as you read up on electronic procedures your want to try them, this is in addition to repairing electricals, but always stay safe, electricity kills if your careless, ive had a few shocks at 240 volts by my own lack of care and attention, i was lucky to have not been killed, please never cut corners, and always follow safe working procedure.
Start on low voltage small projects, you dont need a great vast tool kit to make a start, some of the projects might even become tools you can use in the following of electronics, dont try and jump in the deep end, all of us iam sure at some point, in are interest of electronics started with the basics, its knowledge you learn that will push you forward. Dave.
PS the first books or media you read will give suggestions on what basic tools you can start with.
