GM keyless entry
Chuck Norisez
My GM keyless entry pad is intermittant. Cleaning dosen't seem to help.
Anyone seen a schematic for these things?
Thanks, Chuck
John Robertson
Thanks, Chuck
The problem could be either the keypad, battery holder, cracked PCB, or
the car receiver.
If you have a reasonably fast 'scope you might be able to see the signal
given off by the transmitter - take a short hunk of wire, wrap it around
the transmitter, then hook one end to the probe and the other to the
probe ground wire. Press the button and see if the scope shows something
with the voltage set to the lowest position and the horizontal set to
just about the fastest (except for a VERY fast scope of course!). I use
this setup for testing 21mHz controllers used in old Wall games
(coin-operated arcade games).
Can't you order a replacement module from GM?
If not haunt second hand shops looking for similar units for parts....
John :-#)#
(Please post followups or tech inquiries to the newsgroup)
John's Jukes Ltd. 2343 Main St., Vancouver, BC, Canada V5T 3C9
Call (604)872-5757 or Fax 872-2010 (Pinballs, Jukes, Video Games)
www.flippers.com
"Old pinballers never die, they just flip out."
