Getting crazy with an AD590
rossi
Getting crazy with an AD590JH simply connected to a resistor of 11k/1% :
+5V----
AD590
-------*-------------o
11kOhm ^
-- Vo
--- 0V --- 0V
Vo should be about 11mV/K but I measure 2.7V as indoor temperature
(-24 °C!!).
According to you, where I'm wrong?
Thanks in advance
Dave (from the UK)
+5V----
AD590
11kOhm ^
-- Vo
--- 0V --- 0V
(-24 °C!!).
Thanks in advance
My guess is that the resistor is too high given the suply voltage you
have. I'd suggest decreating the resistor or increasing the supply
voltage. The device needs a suppy voltage of 4 to 30 V, but with a 11 K
resistor you have a lot less than that across the device.
Dave K MCSE.
MCSE = Minefield Consultant and Solitaire Expert.
Please note my email address changes periodically to avoid spam.
It is always of the form: month-year@domain. Hitting reply will work
for a couple of months only. Later set it manually.
amdx
+5V----
AD590
11kOhm ^
-- Vo
--- 0V --- 0V
(-24 °C!!).
Thanks in advance
The Analog Devices pdf shows a series resistor of about
1000 ohms with a 6 volt supply.
Z
ZeroDue
Ok, I'll try. Is there some formula to obtain the resistor according to
the supply?
Thanks to all.
