Hi, this is my first post here..
So basically the water pump on my pc is rated to run on 7v-12v but it's really noisy. It will run at 5v but the problem is that sometimes it won't START at 5v. It's a powerful pump @23w which is too much for the motherboard itself to handle so the manufacturers recommend using a molex from the psu instead.
What I WANT to do is to run it from the 5v molex but give it an additional input from the motherboard fan header to ramp it up when necessary or to give it a boost at startup. Through the fan header I can control the extra power using software so if the temperature sensors in the cpu detect high temperatures it will kick in the extra power.
The fan header on the motherboard is 12v and from what I gather they can handle a max of about 10w but I'd be happier with a max of about 6w - 7w . My thoughts are to put a diode and a resistor from the fan header to the pump in addition to the 5v molex from the power supply.
I've done a few electronics projects in the past but I'm not an expert by any means.
Will this work?
thoughts?
Recommendations?
Will this work?
thoughts?
Recommendations?
