How can I get 24V signal from a sensor output having pulses of 5V?
ramussons Mar 25, 2017 #2 If you are meaning a 24 volt Pulse from a 5 Volt Pulse, I think a simple Transistor/FET amplifier should do the job. What are the Sensor Output Specs? Pulse Frequency, Rise and Fall time?
Minder Mar 25, 2017 #3 A logic level Mosfet, a small one is the 2n7000 up to 200ma. M. Attachments FET2n7000.pdf 831 KB · Views: 61
Minder Mar 25, 2017 #4 Incidentally if the 5v sensor is open collector then you would need a ~10k pull up resistor to use with a FET. M.
