I found this circuit in a cheep rechargeable LED touch. However, as far as I could understand, I saw an issue of this circuit (other than the safety issue). So genius! Please tell me what I think on this, is correct!!
In order to drop the voltage, a Mylar Capacitor is used. Further, the Ni-Cad battery (3.6/700mA) will be charged with 4V/70mA source. However as we know, when the battery-charge go up (after 1-2 hours), the drain current from the source go down (<70mA). However, at the start, the charging current and the voltage was calculated according to “V=IR” and then a capacitor was selected in order to fulfill the above charging-values. So according to this argument, after 1-2 hours, charging voltage on the battery must be high than starting 4V (Ex; if I=30mA then voltage on the battery should go up to 134V). can this be happened ?? Can it make any harm to the battery?
Please see the attach diagram
