N Cook
Actually a repair problem for a low noise microphone pre-amp but seems to be
a general design flaw.
Pre-amp uses a Burr Brown INA103 very low noise instrumentation op-amp.
In this M-Audio Omni i/o preamp and an outline design application in the
Burr Brown book show much the same circuitry.
The 48Volt phantom supply to the mike is protected by 6.8K limiter
resistors.
But to block the 48V DC to the op-amp there is a 10uF/100V electrolytic in
each line directly to the inv & non-inv i/p of the op-amp .
If , as seems in this case, a balanced line microphone with a short to
ground is connected to such a system
then the +48V / 0V across the elecrolytic will instantneously go to 0V
/ -48V with -48V
directly connected to the op-amp i/p powered from +-15V rails and according
to the databook
can be taken to only +-12V.
Blown input to this op-amp due to just the owner connecting a microphone.
Anyone familiar with this, adding limiting diode pair at each input ?
I see no point in replacing this 15 GBP/ 25 USD IC until this design flaw
is attended to or it will happen again should a fault to ground develop in a
mike or lead while the 48V power is on.
resistors.
/ -48V with -48V
to the databook
