GDDR5 addressing
I'm trying to develop a GDDR5 controller and am slightly confused regarding the JDEC spec document - the different memory configuration possibilities all seem to be short three address bits to attain the capacity specified...?
For example 512M memory, 32x mode, with 16 banks:
Row address bits are A0-A11 (12)
Column address bits are A0-A5 (6)
Bank address bits are: BA0-BA2 (3)
(See JDEC spec document JSED212B.01 pg 12 Table 7 and Table8)
But that only addresses 2^12*2^6*2^3=2Mi addressed locations each of x32bits = 64Mbs....
You can do the same with any other configuration listed and still not get the capacity specified. This isn't related to bank groups or the fact that GDDR5 multiplexes it's address lines but clearly there's something else non-standard (different to DDR3) that I'm missing?
Anyone with insights please advise?
You've cross posted the identical question on 2 other forums. That's bad netiquette.
You should at least link to the JEDEC document, don't expect this to sit around on everybody's boookshelf.
You contradict yourself in the question. First you write ...16 banks, then you gon on with bank address bits BA0...BA2 (3) which gives you 8 banks only.
