Heres the procedure I use -
Do a "minimum system checkout" - remove the RAM module/s, video card, any
other card; unplug the hard disk/s and the floppy drive. Basically leave
only the processor/heat sink and the power supply and on/off switch plugged
in. Note that the motherboard will not give any signals with the processor
removed.
Plug it into the power. You should hear a sequence of beeps indication the
absence of RAM modules. If so, then plug in the RAM modules, one at a time,
and try it again - do you get a single beep indicatiog an OK? If so, then
plug in the monitor. Try it again - do you get the main screen come up? If
so, progressively plug in the hard disk/s floppy drive and any other
adapters, till you find the one that's causing the problem.
If you don't get any response with only the processor and power supply on
the motherboard, it is either the motherboard, processor or even power
supply that's faulty.
Henry
