gas discharge tube indentification
Jay1028
I have some GDTs that I can't find any info on. Here are the
markings:
3P90L4 - 3 leaded ceramic
CM3-90 - 3 leaded ceramic
CPC9119M - 3 leaded ceramic
I would like to use them for surge protection on the cable where it
enters the house. I plan on mounting them in a small metal box with
f-connectors at each end. The cable is grounded to a ground rod, I
don't know how long and was installed by the cable company with 3ft
of 12ga wire to ground.
If these can't be identified, how can I test them for breakdown
voltage?
Jay
F
Franc Zabkar
markings:
I'm guessing they are 90V types. The "91" may mean 9 x 10^1.
Anyway I found the following table in this document:
http://www.leutron.de/uploads/media/870010_H35manual.pdf
Table of Tolerances of popular
Gas Discharge Arresters
Uag/N +25%/-20% min Uag max
230V 184V 288V
90V 72V 113V
Uag/N +/-20% min Uag max
90V 72V 108V
230V 184V 276V
voltage?
Jay
I don't know the specs for cable applications, but FWIW the above
document has this to say about telephony:
"The most popular gas discharge arrester is used in telephony and has
a nominal static sparkover voltage Uag/N of 230V with tolerance range
of +25%/-20%. The Uag measured should lie in the range from 184V to
288V."
- Franc Zabkar
