garage door opener
I replaced a circuit board on a garage door opener after it was struck by lightening and the remote will not work. The wall mount switch works. I checked the sensor voltage on the other door with the same brand name and had a reading of 3 volts. I checked the door in question and it is at 80 volts.
You likely have to program it (new board) to your remote control so it can communicate.
Theres usually a learn button that you hold down while someone else clicks the remote.
That way it will learn its code (frequency)
What sensor are you referring to?
I did that numerous times, and it did not reprogram. I also deactivated my other remote on the other garage stall and reprogramed the remote from the problem stall to the functional one and it worked, so it's not the remote. Answer to your question the door sensors.
That doesn't sound healthy. Was your replacement board an OEM one, or a pre-used/anonymous one from some dubious online source?
So we can conclude that the replacement pcb is most probably ok. That leaves the door sensor as the likely culprit.
The sears door photo sensors I'm familiar with use a pulsed 6 volt DC signal that shows up on a digital meter as about 5v.
If the beam us broken or misaligned it changes to a steady 6 volts to notify control board.
Before bying another, You could try swapping the sensors or the boards and see if the problem follows.
Over the Holiday, I swapped out the power units. The one fully functional from my garage stall to my wife's so she would not have to deal with the problem and it worked without having to switch the door sensors.
Does the unit have a switch to allow you to open/close the door? Does this work?
I have a bit information that might be pertinent, when installing the new logic board/ panel I mistakenly put the the colored wires in the wrong place.
We'll, it depends on how it was miswired. But it is certainly a possibility.
It may not be easy to determine what has been damaged.
A good clear image of the board and a description of what wires were connected incorrectly (preferably exactly how they were miswired) may assist us in determining what could have been damaged.
This is the sort of information which is critical and would have been best placed in your first post...
There are three colored wires, one red, three white, two black ,six wires total. One red and white goes to the wall switch, and the final wires to the sensors, one white, one black to each door sensor. I miss wired one white into the two black ones on the logic board.
Here is a description. There three colored wires, one red, three whites, two black for a total of six. One red and one white for the wall switch, one white and one black for each door sensor. I mistakenly put one white wire into the black wire slot with the black wires. Which white wire's place in the mix is your guess is as good as mine.
