I live in Minnesota and have a gas garage heater that is controlled with a simple digital Honeywell thermostat. I keep it at 40 degrees which is as low as it goes just to keep things in the garage from freezing. Twice now (in 3 years) I have left the garage door open and the heater has run all night. I'm thinking of wiring a reed switch to the garage door and to the 24v? furnace on wire of the thermostat so that the heater will not run if the garage door is not closed.
Initially, I was thinking I needed a relay but now I'm wondering if I can run the 24v from the thermostat directly through the reed switch and then to the heater.
I'm just looking for any advice or warnings I'm not considering on why I might not want to do this.
Thanks in advance
Thanks in advance
