Galvanic seperation between channels in TENS unit
rafe
Hello,
I'm building a multi-channel TENS unit. I am wondering if one set of
electrodes is going to affect another set if they're placed nearby each
other. That is: should one channel (set of electrodes) be galvanically
seperated from the others? Can this effect also be done using
semiconductors, thus avoiding bulky/heavy transformers to provide
galvanic separation?
Kind regards,
rafe
t.hoehler
rafe said:
Hello,
Kind regards,
rafe
Short answer, no. The transformers are very necessary, as you will not get
the desired results at the bipolar sites if there is not complete galvanic
isolation. I built many of these units back in the 70's when accupuncture
was "in" and I used those 88 mh toroids you used to be able to get at the
dayton hamfest. they were phone company overstock and could be had for about
a quarter apiece.
Merry Christmas,
Tom
Joerg
a quarter apiece.
Merry Christmas,
Tom
Those toroids were pretty large and are hard to come by these days. An
alternative might be a common mode choke if there is enough isolation
between the windings. A bit unorthodox and one must carefully consider
core saturation but they are certainly a bargain.
Michael A. Terrell
I used one of those 88 mH torroids to replace a missing
output/modulation transformer in a CVB radio back in the early '70s.
That model had a reputation for sounding muddy because it cut off pretty
bad above 2 KHz. The torroid went to about 20 KHz, and the crystal
microphone picked up everything. It didn't sound like the same radio,
after the repair. ;-)
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
rafe
Thanks Tom. I'll be using a CCFL transformer (with custom windings) at
high-frequency to provide a DC +100V, then optocouplers to drive the
output transistors. This way I can use a small core and not have to
worry about slew rates, or generally speaking the transfer function of
an output inductor.
Kind regards,
rafe
t.hoehler schreef:
