G
Glenn Ashmore
In the process of laying up the hull I incorporated a couple hundred sq.
ft of bronze bug screen to serve as a counterpoise. In addition two
runs of 2" copper foil run down the center of the hull to the keel area.
Capacitors between the foil and the keel bolts isolate any DC from
getting back into the counterpoise. That is probably enough but as I am
installing two aluminum tanks, I wonder how kosher it would be to tie
them into the counterpoise with more capacitors.
It would add another 14 sq ft of coupling area but would it be
introducing other problems?
Glenn Ashmore
I'm building a 45' cutter in strip/composite. Watch my progress (or lack
there of) at: http://www.rutuonline.com
Shameless Commercial Division: http://www.spade-anchor-us.com
Glenn Ashmore
