Mark
As a favor to my son's friend, we are trying to repair his Yamaha HTR-5440
Receiver. The symptom for the past few weeks was that the unit would play
for a while and then stop responding to all front panel buttons and the
remote; then the only way to turn the receiver off was to unplug it.
Re-plugging it in would restore operation until the next time that the unit
froze up.
When we brought the unit into our shop, it wouldn't work at all. The low
voltage power is present (+5V, +15V and -15V), but the power-on relay won't
activate, so the display and everything else is dead.
Probing around, I find a clock signal on the microprocessor, running at 10
MHz. I can see the signal from the power-on switch; it goes into a pin on
the microprocessor (+5V when the button is pressed, 0V otherwise). The
output from the microprocessor that is supposed to drive the power-on relay
is always low regardless of the state of the power-on button. Other than the
clock, there is only one other signal on one other pin of the processor that
isn't +5V or ground, and it is a square wave with a 40 msec period. I would
have expected to see other lines transitioning from data transfers, but
nothing.
I don't see any obvious signs of damage, and all of the solder joints look
good. Does anyone have any experience servicing this receiver or ones like
it? Can anyone shed any light on the problem?
froze up.
nothing.
