Do you need optical isolation? I kind of suspect you do as most likely
interfacing with a uPC and mixed 5 and 24V signals in. If that's the case,
best to isolate and not even tie the commons together, which rules out some
of the level shifting digital IC's. Some Opto isolators have parallel
opposite LED's on the input and are used to do the AC signals. I have two
circuit designs that will work for your 5 - 24 Vdc input signals, but will
take a couple hours of my time to draw up, if you have not found a solution
yet. Need more info on your needs too, as to PCB space and # of I/O points.
Can you view AutoCAD 14 / DXF and PDF files?
Wanted: NE IN & Midwest Projects / Position
(will consider other locations, full time or contract)
Electrical / Electronic / Elec. - Mech. / Product / Manufacturing / TEST /
SCADA / PLC / PBC /MES / Instrumentation & Controls / Automation,
Production - Product Tracking PROJECTS or related POSITION
Project Management, Design, Build, Procurement and Commissioning.
Production / Maintenance / Product tracking and data collection / R&D
By Time and Material, By the Job or as Employee
Have Passport Will Travel
DENNIS LEE McHENNEY
(260)-347-9164
E-mail:
[email protected]
5 to 15 Years Experience in following AREAS
? Testing, test system design, building, procurement, and commissioning,
follow-up support and customer service.
? Tough troubleshooting problems & Controls - Instrumentation UPGRADES, PID
loops and control systems.
? PLC, PC and SCADA (Supervisory Control and Data acquisition) systems.
? TESTING: Motors, Gearmotors, PCB's, Electrical-Mechanical Parts, Aerospace
(NASA TEST Facilities) and Automated Test Equipment (FUNCTIONAL, LIFE, ORT
type TESTING).
? MOTORS & Gearmotors: Subfractional - 5,000 HP, AC / DC / ECM
? NO-Load, Loaded, dynamometer, Life, Lab, Production, ORT, Parts (Armature,
Stator, Rotor), HI-POT, Surge.
? PCB's: Design Prototype and TESTING.
? Testers from low cost bench setups through multi-million dollar.
? PLC's: GE Fanuc, AB-Rockwell, Modicon, TI, Keyence and Omron.
? SCADA - HMI - MMI: CIMplicity and TRACKER / RCO's
? Automatic Test Equipment: Meters, Scopes, Dynamometers, Noise & Vibration,
HP-IB.
? Conveyor and production Equipment Controls and Instrumentation, both new
designs and upgrades.
? Hazardous Location controls and instrumentation.
? Project Management and costing.
? Product engineering and support.
? SPC, TQM, DFMEA and MFMEA - PFMEA
? Use AutoCAD, MS Office Pro, CIMplicity, VB and many other software
packages.
Henry said:
These are industrial opto-isolated input modules, cost about
$10-$20/each. Digikey and many other distributors should have an
equivalent if that's what you are looking for- okay, try this number:
Grayhill 70M-IDC5
Best regards,
Spehro Pefhany
Hi, the idea is that I have to design the circuitry because a
constraint on the hight of the board because it is supposed to be
packed on a low profile case (no more than 15mm). I looked at the
module and it looks perfect for my case but it is 1" tall... so there
is no way I can fit it on the case.
So I have to use discrete components to create the interface.
Thanks anyway for your suggestion... I wish I could use one of those..
I saw they even work with a mixed VAC/VDC input... how can they do
that?
Thanks to everybody who's helping me out in my quest.
Regards
Henry[/QUOTE]
