Frequency generator, level adjust
Im using the xr2206 as a square wave generator, but the voltage output of this is too high.
How can I bring the voltage output of this down, without distorting the signal?
Thank You
I need it to be running at 1v peak, I do not know the resistance of what Im using, its a 3vdc transistor radio
a friend of mine used a variable violtage regulator to do this, but I think I want a more basic way to do this
Hello,
Have a look at this ESP project:
https://sound-au.com/project22.htm
Figure 4 shows how to make a signal level control section.
Bertus
This is an excellent reference, but I have a question
Looking at figure 4 of the frequency generator/attenuator website, can the actual attenuator be run from 9v, or should it be lower??
I see the power supply of the attenuator is not shared with the frequency generator....I think, is this the case??
Hello,
Bertus
In the ESP project page, both the oscillator and the attenuator are powered with +Ve, -Ve, and GND, so I don't understand your question.
The attenuator circuit is a unity-gain buffer driving a resistor divider. The buffer (Q1, Q2, etc.) can be replaced with an opamp in the voltage follower configuration if that is easier for you.
ak
I was just wondering if the 2 transistor attenuator stage was powered from a different supply than the actual oscillator stage.
What voltage does the attenuator require?
There is a link to a power supply project near the top of the page.
Looking at the oscillator circuit, I would guess it would run on voltages as low as +/-12 V. The attenuator will run on lower voltages such as +/-9 V, but the oscillator might start to clip.
ak
