Hello everybody
I'd like to modify Francis Deck circuit Phantom Power Piezo Preamp in order to control the output volume of the preamp itself rather than be fixed-gain and have one DIY preamp for my banjo.
The original circuit is the last one in this PDF labelled PPPP: http://personalpages.tds.net/~fdeck/bass/quickand.pdf
My questions are:
Thank you in advance
Sergio
My questions are:
- What is the gain of this preamp?
- Is it possible to change some resistor with a logarithmic pot in order to control the gain from -inf (0 volume) to max gain (top of the volume); I guess I could use a dual-gang 15k pot to "replace" R3/R4 connecting the middle contact of each resistor to XLR contact (respectively XLR+, XLR-), or is there a better way?
- should I tune some condenser value to adjust the bandwidth of a banjo instead of a bass (as far as I understood Deck designed it to be the preamp of his bass)?
Sergio
