Was at some thrift stores picking up too many usb variety cables and power adapters of various kinds and other gizmos and gadgets.
One of them was a DIY multimeter which I want to learn more about. I think it's pretty cool when someone puts their time into something like this and I'd like to be able to make things of some interest as well at some point. Figured at worst I could use the lcd, potentiators , switches, fan, casing even and perhaps get an idea or two. So I haggled it down from $30 to $10 and did some tests:
(Tested using same leads/new batteries)
DIY Multimeter Etekcity
"Sense" (Adjusting current does nothing)
Internal:
USB connected to computer: (V drops A rises, W rises then drops)
External-Manual: Internal-Manual: DCV
AA- 1.625V 1.389V N/A-W&A AA- 1.58V
9V- 6.953V (sense neg too neg) 8.533V N/A-W&A 9V- 9.05V
External-Auto: Internal-Auto:
AA- 1.636V .091V 3.179A .288W
9V- 6.356V .024V 1.326A .346W
"Load"
Internal: ~~
External: ~~
questions/observations:
- not sure what current adjustments are for or how to test it's functionality
- large heatsinks and 2 fans on bottom - not sure what usb function is for, does not power on multimeter, though does change "internal" voltage (perhaps broke)
- way to test usb ports for power in some way? would there be any point to this?
- not sure what sweep is
- afraid to test above 9v as reader indicates 9.999 max read.
- never done a load test other than on a car some time ago, though that is generally beyond 9.999V. suggestions on how to test load quickly and to see if this has any accuracy in that regard
- unstable measurements relative to Elek
- lcd "lights up" when i first turn it on then it loses it's backlight (observational note)
- measures Volts, Watts, Amps
- has manual and auto mode, though not sure what differentiates them beyond internal readings
- the internal readings look like AC readings sometimes
(I was drunk at the time of this posting.... apologies for any oddities(including not taking a close look at the USB soldering before closing it up...))
-James
Internal:
"Load"
Internal: ~~
External: ~~
-James
