This is for small voltage/wattage LED's. Apparently LEDs hooked up in series can have power fluctuations that can break the them. My ultimate question is are there power regulators that don't change the voltage, and are they small enough to regulate a power output of around 120 mA?
My design is to use 3 LEDs at "four V max" and 30 mA each. So if I hook them up to a 12 volt source at 120 mA, it seems I won't have to add any resistors. But the site that sells them says this in-series design can cause I (capital I) to fluctuate. So do I also need a power regulator?
My project is to make a UVB source of 380 nm LEDs, with a reasonable number of LEDs (3 LEDs at 4 volts/30mA using a 12V transformer) is all I can think of right now) to make the most out of the 12V power supply without too much resistance which would waste power and, worst of all, create an unwanted heat source. I have a UVB meter that has it's strongest response to 380 nm in the UVB spectrum in terms of uW/cm^2. I will have to build one of these 3-LED sources of UVB so I can measure their output on this meter. Then I would know how many of these units to put side-by-side to create a sum total of 50 uW/cm2, which is my goal.
Any input is much appreciated.
Roger
Roger
