Clive Mitchell said:
Has anyone tried clusters of LEDs for insect attraction? I'm sure I saw
an advert for a product that used a green LED as the attracting source.
After a quick search of the 'net I can answer my own question to some
degree....
The link below shows an interesting experimental whitefly trap that uses
a "lime green" (530nm) LED to attract the insects. This also tallies
with Sams laser faq mentioning the effect of a high power 532nm laser
being shot into the air and the resultant rainfall of toasted insects.
http://www.ars.usda.gov/is/pr/2002/020530.htm
Another reference to this device is as follows:-
"Technical Abstract: Modifications of CC whitefly traps are in progress
to improve their potential for adult whitefly control in greenhouses.
Adult catches in the modified CC traps have been increased by 50% by
coating trap tops with Tanglefoot and removing the deflector plates. In
laboratory studies, installation of a lime green LED light in the trap
top resulted in catches of 281 adults/trap/24-h compared with catches of
18 and 12 adults/trap/24-h for traps with white LED light and no light,
respectively. Studies are in progress to test the effects of the
modified CC traps on catches of whitefly parasitic wasps. "
That's an increase of 2300% in the traps that had a green LED added. I
bet the researchers had that WAAAAHEY! feeling when they found the
filled traps the next day. The lower count in the White LED traps
suggests that either the other wavelengths are deterring the insects, or
the white LEDs didn't have a dominant peak in the required wavelength.
Since the inverted cup style traps are used out in fields to try to draw
insects away from the crops, I guess that a really neat idea would be to
couple the natural sunshine with the LED technology by making a trap
that worked like a solar powered garden marker. This would charge
during the day and light the LED at night when the trap is most
effective. (And if that's not patented yet, then you can't now, 'cos
I've just disclosed it publicly.)
A search for other forms of fly traps found various versions of a home
made glue board, which were basically bits of yellow plastic covered
with a thin film of Vaseline, or alternatively a mix of Vaseline and
detergent (Do they mix?).
It follows that if anyone wants to experiment with LED based fly
catching effectiveness, then all that is required is a bit of card or
plastic smeared with Vaseline, an LED, resistor and battery pack.
Since it appears that some insects are quite colour selective, it would
probably be a good idea not to put more than one colour of LED on the
card at a time. (But don't let me stop anyone experimenting?)
I wonder what my chances are with catching bugs on the windowsill of a
top floor tenement flat.
