So I'm trying to figure out why a fluorescent light keeps blowing the same fuse immediately in my house.
The other lights on the same fuse work ok until I switch on the fluorescent light. so I assume that's the problem, diagnosing is getting expensive at €1 a fuse!
The fuse (in the main fusebox) is a 10A 500V and it blows immediately once I switch this light on, even with no tube in the fitting. It's a 58w Fluorescent with a 65w starter.
I opened up the fitting, and the light switch, and everything looks ok, no crossed wires or anything. I don't know much about the ballast in a fluorescent fitting.. can a dodgy ballast blow a fuse?
If not I assume it must be a fault inside the wall somewhere..
