Fluke 77 dim LCD display
W
William Sommerwerck
Simply lifting the display from the board and cleaning the contacts on the
board will often fix the problem.
Cleaning the contacts on the LCD is more "iffy". If you have to do it, you
should soak a foam swab in solvent, then "roll" it over the contacts (rather
than rubbing it).
