I have a Fluke 123 Scopemeter that I bought used off of eBay. It has worked great for months after my purchase and I was using it one day to help troubleshoot a problem on one of my vehicles. I powered it off after using it and put it on charge. Later that same day I came back to use it again and it didn't power up correctly.
What I mean by this is with the battery only it would not turn on. When I plugged in the adapter it would power on, I would get a beep like normal and the LCD would be completely black and I could see the backlight was on as well. I pulled the battery to check it and tried powering it on with the adapter only and once again it would not power up at all. The only way to get it to power up was with both the battery and adapter plugged in. With the adapter plugged in I notice that the speaker does a rhythmic clicking. I've never heard it do that before.
I downloaded the Fluke Service manual for it (thank you to Fluke for putting out such a very nice service manual and making it easily available) and I've been slowly working on troubleshooting it but I'm not getting very far. One reason is that while the service manual is very good it doesn't take into account all of the minor changes they've made to the circuits over the service life of the 123 and there are differences that make me have to dig even deeper to see if I've found a problem or just a revision that Fluke made. So my question is has anyone seen a Scopemeter act like the following and what was the issue if you have...
1. Will not power on unless both the battery and the adapter are plugged in.
2. When it powers on you get a normal beep, the screen is black and the backlight is on.
3. With the unit off and the adapter plugged in you here the speaker clicking.
Any suggestions would be greatly appreciated.
