Jamie
Im designing a float charger to keep a heap of car batteries charged in a
car museum.
The batteries are connected to the cars, so they have minimal load (cars are
pre 70's so no ecu load ect)
I so far have made the variable voltage psu +6 and +12 volts, these rails
will be distributed around the building with 2.5mm cable.
The bit im currently deciding on is how to regulate the charge
I have two ways in mind
1) Use a diode and 18 ohm resistor (for 12v rail) on each fly lead from the
wall to the battery, this will result in around 50ma float current, and
voltage pre-set at the power supply
2) Use a diode, and LM317 and 16 ohm resistor between out and adj pin,
forming a constant current supply, voltage would be around 14-16 volts on
the input pin and the reg will provide the voltage drop to keep a constant
50ma current to the battery. - im worried this may overcharge due to the
higher voltage required.
Any suggestions are welcome.
Jamie
car museum.
Jamie
