I have a flexible shaft and would like to have a buzzer telling me the max torsion has been reached.
I was thinking adding a small magnet and Hall Sensor at both end. This way, when the shaft is at rest, both sensors are aligned. When in action, this shaft becomes twisted up to ½ turn (180°).
My challenge is to have a buzzer turned on when the torsion reaches 180°, neither before nor after.
I was thinking using an EXCLUSIVE-NOR gate (4011 or else). When the shaft is not twisted (no force applied), both magnets (or their absence) result with the same levels (HH or LL). When the shaft is active (transmitting a torque), the two magnets are not aligned anymore. This results in different input s to the X-NOR gate so the buzzer can be turned on.
My problem is to have the buzzer turned on only after as much as ½ turn (180°) of torsion is reached and this at any speed. So, a time delay can’t be applied.
Suggestions are welcome, even a complete different approach. Thank you.
