amdx
I parted out a flat screen TV, I pulled an inductor off a board. The
inductor is about 3" long and an inch in diameter. It is wound with a
litz type wire and the value is 5.6uH.
I'm curious, what was the use of this coil. It seemed to carry a
pretty heavy current, because it was mounted with 4 pins on each end and
all four pins were connected to the litz. Also the solder joints to all
the pins were over heated.
So, in what circuit would this be used.
Thanks, Mikek
Thanks, Mikek
