I have a LED array already made, complete with resistors and 9.2V
battery pack. I would like to be able to flash the LED's, with the
speed of the flashing based upon the position of a servo. At 0 degrees,
it would be on all the time without flashing, all the way to 90 degrees
with it flashing 15 or 20 times a second.
To make things harder, this is using the throttle servo from my RC car,
which also controls the brakes. At 0 degrees full brakes are applied,
and at around 15 degrees I think, brakes are not applied and the engine
just sits there idleing. If it's just idleing at 15 degrees it would be
awesome if i could get it to flash for about 2/3rd's of a second
(2/3rd's on, 2/3rd's off) and then when accelorating from there go up
to the 15 or 20 flashes a second. But when applying any amount of
brakes (from zero to 15 degrees) I would like it to be on the entine
time. Does this sound to complicated for an amature like me to do? If
so then a linear change in blinking speed would be OK.
I googled around, and found out that the signal wire for servos sends
the angle information via pulses. 1.25ms for 0 degrees, up to 1.75ms
for 180 degrees, according to:
http://www.seattlerobotics.org/guide/servos.html
However, since my servo is set up with some custom trim levels, is
there any way to find out what the pulse lengths are at various stages
(full brakes, idleing, full throttle) so I don't have to just guess and
check over and over?
I'm fairly new to electronics, and have no idea where to even start to
make this fancy "switch" for my LEDs. I was looking at my old 75-in-One
Electronic Project Lab that I got for my 12th birthday, and the closest
I found was a variable strobe light, which used a transistor,
transformer, some resistors, and a pot, to blink a LED at different
intervals depending on the rotation of the pot.
But that did it based upon the resistance, not pulses, so I am back to
the beginning
I would like to learn as much as possible as I make this variable
switch, so if it is possible, please dumb things down, so I can at
least partially comprehand your idea/point, and google for more info as
needed.
Thanks,
--Farrell F.
P.S. In case this information helps:
I'm using 32 LED's, wired in a series-parallel configuration. 2 LEDs +
resistor in series, with 16 strings wired in parallel. The LEDs are
spec'd for FV 3.0-3.4V, so aiming for 3.2V, I went with 160 ohm
resistors since my power source is 9.6V. Each LED draws ~20mA, so all
32 LEDs draw ~640mA. Perhaps this information effects the components I
should select to make this fancy switch?
the beginning
needed.
Thanks,
--Farrell F.
