flash LED newbie question
I want to build a timer which, when activated, causes an LED to flash
(approx 0.5 to 1 hz, but the precise frequency is not that important)
for 30, 60, 90 or 120 minutes (adjustable). Ideally, power supply
would be 1.5 to 3V. Since I am new, simplicity would be appreciated.
Thanks for any help.
Jan Nielsen
If you are up for a challenge, it can be solved with a PICAXE.
Its a microprocessor that can be programmed in a much easyier way than
the C/assembly processors.
A 08M picaxe is about 3$
A download cable to program it, the same.
The program will be a few simple lines, and you can reprogram the chip
using just the programming cable (and 2 resistors).
It wont be 100% precise, but probaly enough for your use.
If you want to solve it without using a microprocessor, I think the
timing will be the problem.
The blink rate can be done with a 555timer, but the delay for
30-120minutes may be a problem to get precise.
If you want to try with the axe, I can make the program for you.
/Jan
default
/Jan
What would be the bare minimum of parts to get started using a picaxe?
USB cable, software, some kind of prototyping (switch led) board?
What would you recommend for a pic-08?
Jan Nielsen
They have some pretty cheap (From 10GBP) starter sets with cable, board
and a pic.
But if you want to buy the parts alone
PICAXE 08(-M)
Download cable (Can make it yourself, but its 3GBP, so...)
2 resistors (10K and 22K, 1/4W should be fine)
a solderlessboard or something to test on
and some boardpins to make the connecter from the download cable.
if you only have usb, you will need a usb-2-serial converter.
their hp is http://www.rev-ed.co.uk/picaxe/
The 08 is cheap, but its pretty limited with memory, so only useful for
small projects, it will hold about 40lines of basic.
I use 08-M for small projects, and 18X for more advanced projects.
The "hello world" program is to flash a led, but that gets borring fast.
For testing a solderless breadboard will do fine, so you can replace
components.
/Jan
E
ehsjr
For simplicity, use a lamp timer like Intermatic TN111C Lamp
& Appliance Timer ($6.49 at Amazon.Com). Plug a 5V DC regulated
wall wart supply (CAT# DCTX-512 $3.50 at Allelcetronics.com)
into it, and connect the supply to a blinking LED (CAT# LED-4
$0.90 for 2 at allelectronics) through a 100 ohm resistor.
| |---| +|---[100R]---[LED]---+
|TN111C| |DCTX-512| |
To operate, plug the timer in and set the ontime and off
time buttons 30, 60 90 or 120 minutes apart. Then turn the
timer dial until the LED starts to blink. It will blink
for the duration you choose, then stop. It will repeat the
next day and every day thereafter, unless you unplug it.
If you want a little more complexity, the TN111C can
be replaced by a kit: QK152 $12.95 at
http://store.qkits.com/moreinfo.cfm/QK152
It requires a 12 volt power supply (CAT# PS-1251 $8.50 at
allelectronics) and your circuit would change:
| +|-+-| NC|--+
| 12V | | Qk152 |
| Wall | | COM|---[1K]---+
| Wart | | | |
| -|-+-| NO| [LED]
This will increase your cost, but you'll get a little more
electronics experience assembling the kit and adjusting the
timing, and it won't need to be unplugged to prevent it from
turning on again the next day. Later on, once you have
that working as you like, the 12V supply could be replaced
with a DC-DC converter to allow operation from 3 volts
or 1.5 volts. You would likely want to modify the Q152 as well
to eliminate the relay which reduces current drain.
Ed
jasen
Here's one way:
I'd not build it till some of the experts here have checked it over,
I think it'll work, but I could be making some silly mistake.
| This is an ascii schematic, if the diagram appears garbled |
| try switching to a fixed-pitch font (courier works well) |
| pasting it into notepad works well on ms-windows. |
| or in google groups "view source" (found under options) |
.----------[R4]-----------------+--- +3V
30min | / | | | | |
+---/ -->|---[ 1 \_/ 16 ]---+--.
60min | / | | |
+---/ -->|---[ 2 15 ] |
120min | / | | o |
+---/ -->|---[ 3 14 ] |-| restart
| | | o |
| [ 4 13 ] |
| | CD4060BC | |
| [ 5 12 ]------+---[R5]---+- 0V
| [ 6 11 ]-+-[R2]--. +--||-'
| | | | | c2
| [ 7 10 ]---[r1]--| |
| 0V ---[ 8 9 ]--+-||---' |
| `--------------' | c1 |
| | | LED
| `--------|---|<----[r3]--+3V
| | Hi Eff
c2 1nF
C1 1uF
R1 2M
R2 1M
R3 820
R4 100K
R5 100K
Led some high-efficiency type.
Other diodes 1N914 or 1N4148
for 90 minutes turn both 30 and 60 minute switches on.
( 150, 180, and 210 minutes can also be got using
combinations of switches. )
Bye.
Jasen
default
and a pic.
PICAXE 08(-M)
components.
/Jan
Thanks for the ideas.
This looks a lot more promising than the $20 stamps I've used.
I found a seller in the US that has them (08M) pretty reasonable ~$10
for three, ordered that, and a small board for prototyping that
carries the serial jack, regulator, and socket for pic for $8, USB to
serial cable $14, and the "Programming and Customizing the PICAXE
Microcontroller" book for $21.
http://www.phanderson.com/picaxe/index.html Has the stuff - the book
I ordered via ABE books on line.
The 18X is only a little more money.
One question - is there any danger of inadvertently overwriting the
boot strap loader or is that protected?
Jan Nielsen
As long as you use their program there shouldnt be a danger.
Since the chips is regular PICs with a bootloader they can be programmed
in a regular programmer, but then you risk overwriting the bootloader.
phanderson has a lot of other neat projects too :)
/Jan
Jan Nielsen
By the way, check my post in the "Thanks" thread, theres a pretty nice
simulator to catch to stupid mistakes before programming the pic.
although it cant debug much about inputs it can check the code and stuff.
/jan
default
/jan
Thanks again. Can't wait for the stuff to get here. Just got a
confirmation that the book shipped.
I noticed in one blog that the author recommended running at 3 volts
because it makes blowing an output line less likely. 3 V will make it
handy for battery projects.
